LabWindows/CVI
What happened to __FUNCTION__?
I am working on updating a CVI 8.5.1 program to CVI 2013 and have run into the issue that the __FUNCTION__ macro no longer works. There is quite a bit of code that depended on the string concatenation that would happen when you put __FUNCTION__ next to another quoted string
(ex printf(__FUNCTION__", this used to compile");
It now complains that it expected ')'.
When did this change again? They had fixed it in 8.5.1 (8.5 was broke also).
(6,344 Views)
Accepted by topic author ljstrick
The LabWindows compiler has been replaced with clang. Clang is designed to be highly compatible with GCC. The GCC documentation (https://gcc.gnu.org/onlinedocs/gcc-3.3/gcc/Function-Names.html) states:
GCC 3.2 will handle __FUNCTION__ and __PRETTY_FUNCTION__ the same way as __func__. __func__ is defined by the ISO standard C99:
     The identifier __func__ is implicitly declared by the translator as if, immediately following the opening brace of each function  definition, the declaration
          static const char __func__[] = "function-name";
     appeared, where function-name is the name of the lexically-enclosing function.  This name is the unadorned name of the function.
By this definition, __func__ is a variable, not a string literal. In particular, __func__ does not catenate with other string literals.
(6,327 Views)
