LabWindows/CVI
VISA Write Problem (char)
I added printf("%s\n",Addr) after the GetCtrlVal function. It indicated that the Addr string was exactly what I typed in on the front panel.eg,"USB0::0x0957::0x0407::MY44034220::0::INSTR".
The error indicated "invalid resource reference"(VI_ERROR_INV_RSRC_NAME).
Message 11 of 17
(3,267 Views)
So it seems that the VISA help has changed - the constant is the same, but the 'translation' is different....?
My help says
Invalid resource string (parsing error). (VI_ERROR_INV_RSRC_NAME)
In any case: parsing error indicates an error with your string. If this string, entered via your UI, looks fine, i.e. the same as the working string entered directly in your code, all I can guess is that there might be a invisible character, either missing or superfluous. You can check this by using a breakpoint and inspect the Addr value in variable or memory view.
My suspicion would be a line feed or carriage return character
Ha - I just found out that you DO have an invisible character: Try to copy your text from the previous post, i.e. USB0::0x0957::0x0407::MY44034220::0::INS​TR, into Notepad: you will see that at the end there is a character between INS and TR....
Message 12 of 17
(3,260 Views)
Thank you.There's no error. But as I pointed out in the very beginning, the instrument didn't act at all. eg, I send reset command to it but it didn't act. While I send commmand by MAX or Agilent IO Libraries, the instrument react normal.
Message 13 of 17
(3,258 Views)
The Addr string problem has been solved. Now the problem is in the command to be sent.
switch (event)
		case EVENT_COMMIT:
			GetCtrlVal (panelHandle, PANEL_ADDR, Addr);
			GetCtrlVal (panelHandle, PANEL_COMMAND, Comm);
			//printf("%s\n",Addr);
			//printf("%s\n",Comm);
			errstat=viOpenDefaultRM (&defaultRM);
			//if(errstat != VI_SUCCESS)
			//	printf("viOpenDefaultRM() Problem\n");
			//else{
				//errstat=viOpen (defaultRM, "USB0::0x0957::0x0407::MY44034220::0::INSTR", VI_NULL, VI_NULL, &vi);
				errstat=viOpen (defaultRM, Addr, VI_NULL, VI_NULL, &vi);
				printf("viopen() Problem\n");
			else{
				printf("Open USB Dev just fine\n");
				//errstat=viPrintf (vi, Comm);
				errstat=viPrintf (vi, "*RST\n");
					printf("viprintf() Problem\n");
				else
					printf("VisaWrite USB Dev just fine\n");
			viClose (vi);
			viClose (defaultRM);
			break;
	return 0;
 If I use errstat=viPrintf (vi, "*RST\n"), the instrument acts normal. If I use errstat=viPrintf (vi, Comm) instead, the instrument didn't act ,with no error.
Message 14 of 17
(3,253 Views)
How did you solve it?
Message 15 of 17
(3,248 Views)
Concerning your command string: are you sure the command string Comm also includes a final "\n"?
Message 16 of 17
(3,247 Views)
About the Addr string format.AS you pointed out,the Addr string should be complete.There's a "?" between INS and TR in the Addr string at first.Secondly, the string cannot include "" .
Thank you very much. I'll do more debug to see the problem about the command.
Message 17 of 17
(3,245 Views)
