LabWindows/CVI
Using thread safe variables in a multiple file project
File with delcaration
DefineThreadSafeScalarVar( int, TsvGetMsg, 0)
in file a. I need to access the variable with GetTsvGetMsg(); and SetTsvGetMsg(1); in another file. How do I let the compiler know where those TSV definitions exist. That is, the decalaration was in file a and I want to use the variables in file b. How do I do this?
(4,114 Views)
Use the DeclareThreadSafeScalarVar macro in a header file and include that header file in the source files that need to reference the variable.
David Rohacek
(4,114 Views)
The compiler complains of multiply defined...
Then spews out all of the TSV macros
(4,114 Views)
Hi there,
If you look at the class help for the Thread Safe Variable class (Utility >> Multithreading >> Thread Safe Variable >> Class Help), you'll find a topic on using DefineThreadSafeScalarVar and DeclareThreadSafeScalarVar. According to the class help:
"If you want to use the variable in more than one source file, put the following line in a header file that you include in the source files that use the variable:
DeclareThreadSafeScalarVar (int, MyCounter);"
Do not place the DefineThreadSafeScalarVar in your header file, as this will create multiple definition errors.
Good luck,
Azucena
(4,114 Views)
