LabWindows/CVI
Using static MSVC6.0 compiled libraries from LabWindows/CVI
I tried to use a static library (from third part supplier) compiled with MSVC 6.0 from LabWindows/CVI.
1. I added #include "MyLibrary.h"
2. then I added MyLibrary.lib into project
but I get linker error messages - "undeefined symbol ""MyLibraryFunctionName""
(3,380 Views)
CVI is not a C++ compiler so make sure you compiled your library with your functions in C format with extern "C" statements. Also, you should list the VC++ and CVI version you are using on this type of question. An older version of CVI might not read a static lib from VC 6.0.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,380 Views)
