LabWindows/CVI
Using problems MS Winsock Control In CVI
Hi.
I'm have problems using MS Winsock Control(ver 6.0) in CVI
When data send to another system, I set to 'variant' type from variable or array.
And send to another system.
problems is..
Set to variant type from variable(int, double, float...) is a good. (no problem)
But 1D array(int i[10], double d[10]...) is a bed. (problem)
my code is..
1. variable(no problem)
int  i=10;
CA_VariantSetInt (&varData, 10);
MSWinsockLib_IMSWinsockControlSendData (hSocket, NULL, varData);
2. 1D array(problem)
int  ia[10]={1,2,3,4,5,6,7,8,9,10};
CA_VariantSet1DArray (&varData, CAVT_INT, 10, ia);
Answer me. please.
Sorry..my english is not good.^^;
Best regard!
(4,022 Views)
Hi, jecki.
Can you tell me a little more about what happens when you call MSWinsockLib_IMSWinsockControlSendData ()? I don't really understand what is going wrong.
Have a nice evening!
Sarah K.
Search PME
(3,996 Views)
Hi Sarah.
int  i=10;
This(1) case a confirm to 'Data Arrival Event' commit to receiver system.
And, receiver system can get data.
This(2) case a not confirm to 'Dara Arrival Event' commit to receiver system.
And, receiver system can't get data.
regards.
Jecki.
(3,991 Views)
Hi, Jecki.
Those ActiveX wrappers can often be difficult to use; I recommend instead using some of the methods in the TCP or Datasocket libraries. (You can find them in the lower-left panel of CVI -- see screenshot.)
There are several examples of both of these libraries in the Example Finder. You can access them all by selecting Help>>Find Examples and then selecting Networking>>TCP or Networking>>Datasocket. The TCP examples MessageReader and MessageWriter are particularly nice and simple examples.
Let me know if you continue to have problems. Have a nice evening!
Message Edited by sarahk on 07-27-2006 07:15 PM
Sarah K.
Search PME
(3,972 Views)
