LabWindows/CVI
Using duplicated panels
Hi. My application must open similar panels to control remote devices. Considerng that I don't know the exact number of the devices, I drew only a panel and I'd like to create a new panel using DuplicatePanel to handle each device. That function gives me back the new panel handle, but I have no information about the control IDs of the new panel, so I can't work with it.
Have you got some advices ?
(3,351 Views)
The control IDs will be the same as on the original panel. Don't forget that whenever you access any control, you always specify the panel handle that the control is on, so there will not be any confusion as to which one you want to use.
JR
(3,346 Views)
Ehm... I didn't think about what you said... It's true !!
Anyway, thank you very much !! Smiley Happy
(3,337 Views)
