LabWindows/CVI
Using PFI output as static line and then pulsing.
I would like to know if it is possible to use a PFI output on a USB-6212 as a static output and then pulse the output?  I am using the output as a control to a switch and need to generate a pulse to interrupt the switch.
Thank you
John
Message 1 of 9
(4,445 Views)
Hello John,
Yes, it is possible but keep in mind that the digital lines of the USB-6212 are restricted to software timed operations. If you need a hardware-timed pulse you will need to use the device's counter(s).
Message Edited by ManLongAtNI on 06-01-2010 05:12 PM
Glenn
Message 2 of 9
(4,397 Views)
Thanks, could you give me some steps or an example?
I am using CVI 9.1.
Regards
John
Message 3 of 9
(4,394 Views)
Hello John,
There is an example called WriteDigChan.prj that shows how to write to a digital channel. This example can be found in the NI Example Finder when you Browse according to: Task, under Hardware Input and Output>>DAQmx>>Digital Generation. Just use the DAQmxWriteDigitalLines() function to toggle the line of interest.
Glenn
Message 4 of 9
(4,371 Views)
Maybe my question was not clear.
I need to use the digital line as an on/off signal that drives a FET.  When the line is low the FET is OFF, when high the FET is ON.  I need to pulse the line (while it is high) at various low pulse widths (from 10us to 10ms).  The FET is being used as a power switch that I need to interrupt by setting it low for the specified times then return high to keep power ON.
I know how to use the lines statically and how to use them to generate pulses.  Is there a way this can be done without doing a DAQmxWriteDigitalLines() to set it high or low and using Delay() for the pulse width?  The Delay() function is not accurate in the 10us range.
John
Message 5 of 9
(4,364 Views)
Hello John,
Can you clarify with an image of  pulse the line (while it is high) at various low pulse widths (from 10us to 10ms)?
Glenn
Message 6 of 9
(4,342 Views)
Glenn
I hope this clarifies what I am trying to do.
Regards
John
Message 7 of 9
(4,322 Views)
Hi John,
no software command will be guaranteed to work on such short time scales; instead you should consider using one of the two hardware timers of your instrumentation.
Wolfgang
Message 8 of 9
(4,317 Views)
Hello John,
Wolfgang is correct, to get 10us pulse you will need to use the counter. For an appropriate example, reference the Example Finder, Hardware Input and Output>>DAQmx>>Generating Digital Pulses and reference the DigPulse.prj. Set the Idle State to High and define your pulse.
Glenn
Message 9 of 9
(4,243 Views)
