LabWindows/CVI
Using Digital Filter
I have a buffer, its length is 190000, I plot this data on a stripchart, it has 19 traces and its size is 9999, but now I need to apply them a filter before the plotting, How could I do that? I´m using CVI
Regards
(3,660 Views)
Hi hahr,
You can go to "Library" on the main menu, then select "Advanced Analysis". That'll open analysis.fp.
Then, select "Signal processing" and you'll find IIR/FIR filters as well as windows and other useful things.
Hope this helps.
svk
(3,629 Views)
How is your buffer shaped i.e. do you have a two dim array of numbers of size 19x10000 or do you a 1D array of size 190000. Either way, you will first need to seperate out each signal (of size 9999) and then feed that array into a filter function. There are several filter functions available in CVI. For example the Bw_LPF function performs a Butterworth low pass filter on an array of numbers. You can find these and more in the built in libraries under Advanced Analysis Library>>Signal Processing>>IIR Digital Filters.
Hope this helps
Jack J.
(3,628 Views)
