LabWindows/CVI
Using DLLs in Dev-C++
Hi All,
I realize that this post has very little to do with CVI, but everyone in this forum has been so helpful before.  Anyways, for financial reasons I wanted to write code for my MultiDaq 6024E card in the Open Source Dev-C++ and was wondering if I could simply use NI DLL's to talk to the card.  I believe I would be able to use the Traditional DAQ functions alright, but how about DAQmx.  Anyone with information on this please let me know.  Thanks.
Cheers,
tdk
(4,908 Views)
Hey Tdk,
Good news, you can use standard C to call any DAQmx functions.
Step 1: Install DAQmx driver. Free download http://digital.ni.com/softlib.nsf/websearch/7FEAEE6A4B4AA836862571C00064E6CA?opendocument&node=132060_US
Step 2: Open Start»National Instruments»NI-DAQ»NI-DAQmx C Reference Help
This document will help you understand all functions.
Step 3: Start with an example. Browse C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
You will notice you can use other programming languages. If you need C++, you will use VB .NET or C#. The help is called DAQmx .NET Framework.
Good luck!
Yardov
Gerardo O.
RF SW Engineering R&D
(4,888 Views)
Hey Yardov :
            Thinks for your info, now i am in the kind of same stiuation with Tdk but I use VC6.0, I finished step 1, 2,and 3. I put a C file from these examples and the NIDAQmx.h, the head head file into a project, however I ran into some  link error2001: unresolved external  symbol_ DAQmxClearTask@4..... like this
so, do you have any idea about this problem?
        Cris
(4,454 Views)
Hi Cris,
Have you tried running the shipping examples as mentioned by Yardov?  These file are installed with the free DAQmx driver from ni.com to Start»All Programs»National Instruments»NI-DAQ»Text-Based Support.  Please give these examples a shot to see if you encounter the same error.
Best,
Adam
Academic Product Manager
National Intruments
(4,425 Views)
Hi  Adam,
        thinks for your reply, It's my complier's problem, i reconfigured it and got the problem solved. by the way , i noted that all the examples provided by DAQmx are about acquire data by with a single channal, can you show any code about acquire a continuous amout of data with two or more channels?  thinks
(4,412 Views)
Hi Cris,
Here is a good document that describes the syntax for DAQmx channels, which discusses adding multiple channels to the same task.
Best,
Adam
National Intruments
(4,389 Views)
