LabWindows/CVI
Use shared variables with FPGA device on Host PC
Hi all I am having a frustrating problem. I am trying to use shared variables linked to a cRIO 9012. The shared variables were created and then written to in a RT vi. is there any way I can assign locations to these not within a RT vi. I altimately need to run the Host vi on a TPC-2512 touch panel computer and I can't run a RT application on that. I just need the variables to update without the RT vi running and I can't figure out how to do that, if its even possible. Here is what I have so far. Thank you in advance for your help.
(3,059 Views)
it appears to me that you have chosen the wrong forum... This one is about CVI / LabWindows, not LabVIEW. Your problem will be better answered if you repost it in the appropriate forum.
Good luck,
Wolfgang
(3,038 Views)
