LabWindows/CVI
Universal Library
Dear I am not able to understand how to use 'Universal Library(UL) by Mesurement Computing ' within Labwindows. Mesurement Computing described ways and provided 'lib' and 'header' files for C, VC++ but not for LabWindows. They also explicitly described to use UL for LabView. Kindly inform me how can I uses UL within LbWindows. Can I use lib and header files provided for integration with 'C' in case of LabWindows
Raheel
(3,679 Views)
Accepted by topic author Rahil
Hello Rahil,
LabWindows/CVI is just an ANSI C developement environment with some special Data Acquisition libraries included. This means that any C code should be able to compile in LabWindows/CVI as long as it pertains to the ANSI standards
Peter Flores
(3,634 Views)
