LabWindows/CVI
Unexpected Button Labels
I have an app I built in LCVI 2009.  This app runs just fine on many different PCs (WinXP, Win 7, x32, x64).
However, on a couple of PCs, the app exhibits a very strange problem.  The button labels on a ConfirmPopup panel are not labled "Yes" and "No", as expected.  Rather, they are labeled "Load" and "Make Directory", respectively.  See the attached screen shot file.
My guess is that this has to do with incompatible libraries, maybe from earlier versions of LCVI.  We have been using LCVI since version 5, so some PCs may have lingering libraries from way back when.
Any ideas on what the problem could be?
(3,746 Views)
I seem to remember that I recently saw a simila question but didn't succeed in finding it. I just found out this old thread which may be of some help. Anyway, button text should be taken from a message file installed together with the CVI Runtime Engine, so removing and reinstalling it should solve the problem.
(3,732 Views)
Do you happen to know the name and location of the message file?  I'd like to take a look at it...
Thanks.
(3,719 Views)
It is listed in the thread I linked in my previous answer. Location depends on the OS you are using so it's better that you look there and find the correct one.
(3,711 Views)
