LabWindows/CVI
Unable to call function from DLL.
I am trying to use this CAT analyzer tool. (http://www.ime-actia.com/web_can/software/cat_api_driver.htm)
And I cannot call functions from CatiAPI.dll. I am getting undefined symbl error. I have attached my project and all dlls needed. Please help.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,170 Views)
It's possible that the DLL and LIB were built for C++ and that your problem is in the function name mangling of C++.
Check with the CATI supplier.
When I build DLLs in VC++ for use with CVI, I wrap all the exported functions with
// call everything extern C if a C++ compiler is used
#ifdef __cplusplus
extern "C" {
#endif
// exported functions
// end of extern C block if a C++ compiler is used
#ifdef __cplusplus
#endif
(3,145 Views)
Thanks for reply. I ended up modifying h file and created new lib from new h and dll. and that seem to work fine.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,136 Views)
