LabWindows/CVI
Unable to Open Source Code Control Project - Perforce
Wahoo.  I figured it out.  Basically, I had my root and view mapping screwed up.
I had the root set as follows:
c:\Sandbox
And the Depot mapping as follows:
//depot/TestEngineering/LP15/... //njaLP15_Powerage/TestEngineering...
When, what I should have had was the following
Root:
C:\Sandbox\TestEngineering
View:
//depot/TestEngineering/...  //njaLP15_Powerage/...
Message 11 of 13
(1,633 Views)
Hi NJA,
Yeah, setting up all the correct configurations is always a little tricky sometimes. Glad everything is working.
Best Regards,
Jonathan N.
Message 12 of 13
(1,630 Views)
I just want to add a quick comment to this thread.
I had the same problem eventhough my path was setup correctly it would always get the SCC_E_INVALIDFILEPATH error.
I was able to fix the problem by changing the perforce root directory to use forward slash (/) instead of backslash in the perforce GUI.
first it was: c:\work
changed it to c:/work
and now I can change between perforce clients/workspaces without a problem with CVI.
-Roy
Message 13 of 13
(1,438 Views)
