LabWindows/CVI
USB support
I use LabWindows/CVI in its last version and need to write an interface to
an USB device (medical DSP amplifier) which will be designed in the next
months.
Will LabWindows/CVI support low level USB functions in the next version or
are there any Windows SDK Libraries available to handle the WIN98/WinNT built
in USB functions?
(5,411 Views)
Is there an answer to this one yet? Does CVI support USB communications?
(4,469 Views)
You should be able to communicate to a USB device by configuring the device using the NI-VISA drivers.  A short tutorial can be found here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
(4,464 Views)
Creating and installing the INF file didn't work. I got the correct vendor ID (0C2E) and product ID (0206) and created the INF as per the instructions. But I could not install/update the driver for my device. The device I created does not show up in the Hardware Update Wizard window.
No matter what I do, it only want to install the standard windows drivers.
This happens on two different Windows XP computers.
(4,448 Views)
