LabWindows/CVI
UI Localizer Error
Hi!
When I load my UIR file into the Localizer I get an assertion failed message box (line 1367, file uiobjects.c) :(. Why?? Is there any solution?? Maybe new Localizer version, patch or something...
(3,270 Views)
This seems to be a problem. The recessed narrow frame box is causing this error. Your panel works fine once I remove the decoration box from your UIR. Seems like this problem is fixed in CVI 7.0
Bilal Durrani
NI
Bilal Durrani
NI
(3,270 Views)
