LabWindows/CVI
UDP: connected timeout
I am using CVI 6.1, I have an application talking to a sterobocope via UDP using the winsock example from NI site. but get connected timeout error every time when receiving data from the sterobocope .
even if I use the example itself to write and read in one PC, it also get connect timeout error when run UDPRead.prj .however, the UDPWrite.prj works well.
whe ?
thanks a lot for answering!
(3,487 Views)
the problem had been Smiley Happysloved!
(3,472 Views)
