LabWindows/CVI
Trigger value change event
Is there a way to trigger value change event, like the one in LabVIEW?
In Key press event.
George Zou
(3,142 Views)
Is there any particular reason for not using EVENT_VAL_CHANGED event?
(3,130 Views)
@Roberto: I suppose that this request is to be understood in the context of these two posts: here and here
@George: Since recently CVI has an Idea Exchange (here) where you might request additional events: While it does not answer your question in the short term it might help in the long term Smiley Wink
(3,124 Views)
