LabWindows/CVI
Transparent bitmap on canvas
OK, so I'm working on a workaround for this bug. Basically I read my picture rings and generate new canvases on which I put the images from the ring. Then I just put whatever canvas I want on top. Except that there's a problem with the transparency of the images which gets lost in the process:
	int j, New, Bitmap, Left, Top, Width, Height, Pre[3]={1,3,2};	// Only some colors
	for (j=0; j<Nb; j++) {
		GetCtrlBitmap   (Pnl, PNL_PICRING, i, &Bitmap);
		GetCtrlAttribute(Pnl, PNL_PICRING, ATTR_LEFT,  &Left);
		GetCtrlAttribute(Pnl, PNL_PICRING, ATTR_TOP,   &Top);
		GetCtrlAttribute(Pnl, PNL_PICRING, ATTR_WIDTH, &Width);
		GetCtrlAttribute(Pnl, PNL_PICRING, ATTR_HEIGHT,&Height);
		New = NewCtrl (pDgrm, CTRL_CANVAS, "", Top, Left);
		SetCtrlAttribute(Pnl, New, ATTR_DRAW_POLICY, VAL_MARK_FOR_UPDATE);
		SetCtrlAttribute(Pnl, New, ATTR_WIDTH,  Width);
		SetCtrlAttribute(Pnl, New, ATTR_HEIGHT, Height);
		SetCtrlAttribute(Pnl, New, ATTR_PICT_BGCOLOR, VAL_TRANSPARENT);
		CanvasDrawBitmap(Pnl, New, Bitmap, VAL_ENTIRE_OBJECT, VAL_ENTIRE_OBJECT);
		DiscardBitmap(Bitmap);
	SetCtrlAttribute(Pnl, PNL_PICRING, ATTR_VISIBLE, FALSE);
 Am I forgetting something about transparency ?
(3,679 Views)
Hi gdargaud,
Are you expecting to have the bitmap drawn into the canvas be transparent?
Humphrey H.
(3,658 Views)
Accepted by topic author gdargaud
Yes. Actually, reading the documentation, I figured out it's actually simpler to use a picture control instead of a canvas. I had forgotten about those. Case closed. But could you please answer my other thread about the major memory leak when using picture rings, which is actually the reason I'm using this workaround ? Thank you.
(3,655 Views)
