LabWindows/CVI
Transparent bitmap on Image Button in CVI panels
i need to use a image on a Lbwindows/CVI Panel.
I've used the image button control and then i've loaded an image that have a transparency inside.
When i load the image, the transparency is set as a white color. My problem is that i need to have the transparency in order to see the panel background and not the white color of image control.
I've used all format (bmp, pcx etc...) provided by the image control without results...
Can anyone help me?
Thanks anyway,
Maurizio.
(3,079 Views)
Hi, Maurizio, look at this suggestion from Alex: it's great and I have personally used it exactly on a picture button with good results.
(3,073 Views)
