LabWindows/CVI
Transfer ASCII Files Over VPN
Currently we are using FTP to transfer ASCII test records from our contract manufacturers to a local FTP server.  We have been having issues of corrupted files as well as lost records for a very long time.  Many different attempts have been performed but nothing seems to be perfect.  We are also now running into performance issues.  Since FTP is based on TCP/IP I am hoping there is a faster solution.  What I am looking to accomplish is to:
Establish a connection from a PC to a network drive that may or may not be available through a VPN (network connection could be down).
If the drive is available then - Transfer ASCII files from local machine to network drive
                                              Verify file integrity
                                              Disconnect connection
If the drive is not available - Write a log on local machine and try again later
I am slowly learning the proper usage of both Datasocket and TCP/IP but I have to believe thier is an easier way.  I am using CVI 5.5 and/or 8.5.  If anybody can give some direction I would greatly appreciate it.
TOM B
Message 1 of 1
(2,855 Views)
