LabWindows/CVI
Threadsafe Modal Dialog
Is there any way to do a thread safe, properly operating modal dialog panel?
I want to issue popups from within a thread.  Using the standard MessagePopup() displays the dialog box, but it does not block events in the other threads.  Which is to say that one can click anything else on the main panel, putting the popup in the background.
Perhaps there is some kind of signalling that can be implemented between a function launched from the thread via PostDeferredCall(), so that the thread pauses until the popup is closed?
(3,320 Views)
hendra:
 If you just need a simple, standard dialog box, you can use the Windows SDK MessageBox function to create a system modal dialog box.  System modal dialogs stay on top of all other applications.  See my old example here: http://forums.ni.com/t5/LabWindows-CVI/MessagePopup-dissappears-behind-active-panel/m-p/182045#M1409...
If you need a more custom dialog, as an experiment I created a CVI project which simulates a system modal dialog by taking back focus on a fast firing timer.  See my discussion and example here: http://forums.ni.com/t5/LabWindows-CVI/Make-panel-modal-from-a-CVI-dll/m-p/1316925#M50035
(3,315 Views)
