LabWindows/CVI
Threading Bug
I am writing an application that downloads data from the internet using threads. I use thread callback functions extensively and from the callback function I will often create new download threads to download addition data (ie: pictures, data, etc that are links from the first data).
Every so often I get a crash bug that I can't debug. So, I modified the simple OnePanel.c example to behave more like my program. Instead of a while(1) loop, each thread loops 100 times, and then a new thread is created in the callback function. 75% of the time when I run this code I will get a similar crash if I click on the 'new thread' button often.
Any ideas?
Thank you,
Alan
(3,424 Views)
This crash somehow seems to be related to schedule a threadpool function using the callback. If you set the callback parameter to NULL, you dont seem to get the crash anymore. I'll forward this bug report to R&D for further investigation.
Bilal Durrani
NI
Bilal Durrani
NI
(3,422 Views)
Is there a workaround or a fix for this?
(3,380 Views)
I used the Thread Safe Queue mechanism to queue up a pointer to a structure that included the callback pointer. I was able to simulate a callback by queueing up the callback at the end of the thread function. This seems to work pretty well.
Alan
(3,360 Views)
