LabWindows/CVI
ThreadSafe Variable in CVI
I am just starting out with ThreadSafe variables and I have no problem with them as long as I am within the same file. How do you use them in multiple files?
in main.cpp
typedef struct
} X;
DefineThreadSafeVar(X, tmp);
in main() I Initialize it
I can have routines in the main.cpp file that use GetPointer to and ReleasePointer to with no problem,
but I have a timer in another file that needs to access that data. If it was just a normal variable, I know that extern X tmp would work.
How do you do that?
Thanks in advance!!
Lee
(4,141 Views)
Hi Lee,
See if this discussion forum post here helps you out. This should be what you are looking for.
Best Regards,
Jonathan N.
(4,134 Views)
Hello Lee.
I think you will find your answer in this thread.
Good luck,
Colin.
You're too quick for me, Jonathan Smiley Happy
Message Edited by cdk52 on 02-14-2008 08:26 AM
(4,132 Views)
Thanks guys, that does the trick!
Lee
(4,118 Views)
