LabWindows/CVI
Thread safe queue (TSQ) help
I have two threads running in my application:
1. Time crtical thread. This thread reads 4 channel DAQ data from DAQ board, 1 data from a series port, and calculates time interval from a timer. The whole process will take about 0.01 s (100 Hz) and this thread will collect about 60000 data points.
2. Real-time data analysis and display thread. This thread will save, analyze, and display the data collected from thread 1 in real time. This thread will also process system events. One of the time consuming process is displaying two sets of data in a graph.
Since thread 1 is much faster than thread 2, in order to avoid queue overflowing. I am going to use the following TSQ structure:
1. Create a thread queue with a length of 60000 with a thread queue read callback function which will read the queue when the item number in the queue is 600.
2. In thread 1, I am going to write the queue every 60 points.
Will my algorithm work correctly? Or anyone has a better solution for my case? Thanks
(4,619 Views)
Anybody can help me? thanks.
(4,597 Views)
It seems like your general logic is sound.  Your overall application architecture sounds good as well.  This scenario is the perfect case for a queue.  There is a CVI example that is somewhat similar to your application.  It is acquiring data and sending it out across the network through TCP/IP.  There is one thread for sending the information across the network and another thread for acquiring the data, and the two threads communicate via a TSQ.  You can get to the example by going to the CVI example finder and searching for queues.  Hope this helps.
Pat P.
Software Engineer
(4,595 Views)
Thanks Pat. If the algorithm is correct, I have questions about the queue write and read:
    CmtInstallTSQCallback (tsqHandle, EVENT_TSQ_ITEMS_IN_QUEUE,
                                            600, QueueCallback, NULL,
                                            CmtGetCurrentThreadID(), &plotDataCallbackID);
   CmtWriteTSQData (tsqHandle, writeBuffer, 60, 0, NULL);
   CmtReadTSQData (tsqHandle, readBuffer, 600, TSQ_INFINITE_TIMEOUT, 0);
 The above functions are what I used for my queue. I am wondering when my QueueCallback will get called? According to the explaination of EVENT_TSQ_ITEMS_IN_QUEUE, the callback will be called when a. items are written to the queue. and b. number of items exceeds 600. However, as I debug my code, I noticed the QueueCallback will only be called when the queue is full (60000). What happened?
Thanks.
(4,592 Views)
Your assumptions are correct.  The callback should be called as soon as you have a write in which the number of items in the queue meets or exceeds 600.  I wrote a small example here using the same functions, and the queue functioned as expected.  I would recommend starting with simulated data to see if you can get your queue to work properly.  If you have a stripped down version of your project, you could post it here for us to take a look at.
Pat P.
Software Engineer
(4,575 Views)
