LabWindows/CVI
Text Box read
does anyone know how to read data from the Box text?
I am using the following code to read data from a file:
g_fileh = OpenFile ("GPSlocation.txt", VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII);
read_number = ReadLine (g_fileh, line, 500);
SetCtrlVal (panelHandle, PANEL_BESTGPSPOS, line);
DecodeGPS (line);
SetCtrlVal (panelHandle, PANEL_INSPVA, line);
DecodeGPS (line);
CloseFile (g_fileh);
Which command instead of ReadLine should I use for read directly from texBox?
Thank you for your help.
(2,681 Views)
SetCtrlVal = Writing to a control (e.g. a Textbox)
GetCtrlVal = Reading from a control
(2,666 Views)
I have already tried it, of course, but it does not work for me.
(2,663 Views)
In this case you'll need to add some more details describing your problem: which message is read from file and written to the textbox, what you are retrieving, why "it does not work for you", if any error message is received... all relevant informations that can describe the situation and help us to help you.
(2,653 Views)
