LabWindows/CVI
Test Stand Report GEneration
How to disable/enable test report generation in Test Stand  programmatically using CVI application?
Priya
(3,152 Views)
Hello Priya,
You can disable or enable report generation in TestStand by adding the ReportOptions callback to your sequence file.  Then you can use the following statement to turn reporting on or off:
Parameters.ReportOptions.DisableReportGenerations = <boolean>
This is discussed in greater detail in this KnowledgeBase article and this forum post.  I hope that helps!
Marty H.
(3,119 Views)
