LabWindows/CVI
TelNet for CVI
I use LabWindows/CVI in its last version and need to write
an aplication that connects to a telnet server.
Is there any example how to implement telnet in CVI?
Thank you,
Andre
(5,273 Views)
Andre,
Telnet is protocal based on TCP/IP. Therefore, you can use LabWindow/CVI
to build a program that uses TCP commands, which are in the TCP library, to
create a Telnet application. This might be a bit difficult becuase it
requires knowledge of the Telnet protocal. A simpler solution is to use a
Telnet ActiveX component. I have searched the web and found a number of
Telnet ActiveX component that you can use.
Ali AlHasan
National Instruments.
Andre Pristat wrote in article
<382c2825@newsgroups.ni.com>...
> Thank you,
> Andre
(5,273 Views)
Thank you for the responce Ali,
but so far I know (also discused in this NG) CVI only
supports ActiveX Automation, so I can't use TelNet ActiveX components.
Regards, Andre
"Ali AlHasan" wrote:
>Andre,>Telnet is protocal based on TCP/IP. Therefore, you can use LabWindow/CVI>to
build a program that uses TCP commands, which are in the TCP library, to>create
a Telnet application. This might be a bit difficult becuase it>requires
knowledge of the Telnet protocal. A simpler solution is to use a>Telnet
ActiveX component. I have searched the web and found a number of>Telnet
ActiveX component that you can use.>>Regards,>Ali AlHasan>National Instruments.>>Andre
Pristat wrote in article><382c2825@newsgroups.ni.com
>> I use LabWindows/CVI in its last version and need to write>> an aplication
that connects to a telnet server.>> >> Is there any example how to implement
telnet in CVI?>> >> Thank you,>> Andre>>
(5,273 Views)
Andre,
I am sorry for the miscommunication. I was actually referring to using a Telnet ActiveX
server not control. If you have a Telnet application that exports a Telnet method then you
can use that as well. You might also be able to find a DLL that has a Telnet function.
If you can't find either then you will have to build a Telnet application based on TCP
functions.
Ali
> Regards, Andre
> Pristat wrote in article><382c2825@newsgroups.ni.com>...>>
(5,273 Views)
If you can used DLL, take extrputty software.
This software is addon of putty and offered telnet API for teststand in order to send and received data.
I hope that can help you.
extraputty.free.fr
Message Edited by Support on 02-04-2008 08:58 AM
(4,645 Views)
