LabWindows/CVI
Table with many rows
I' m using Labwindows CVI 6.0 and 10SP1 .
If my used table holds more then approximatly 20000 rows the application crashs with diffuse errors.
The Count of Columns is 20. One column can hold a bitmap, but it also crashes if no bitmap is in any cell.
Can everyone give an answer wy it crashes and what I can do ?
(2,964 Views)
Hi hwh,
Do you mind answering a few questions that might help us identify the problem?
1. Does the crash happen equally with the 6.0 Run-Time and the 2010SP1 Run-Time?
2. What do you mean by "diffuse errors"?
3. Does the exact error code and the location of the error vary, or is it always the same? If it varies, how many different error permutations have you observed?
4. Would it be possible for you to reproduce this problem in a small test program and attach it here?
Luis
(2,947 Views)
