LabWindows/CVI
Tab browsing
    Hi all
I have got an uir File with a lot of "Edit Strings", when I start the application and want to enter sth. in the fields I would like to change between the fields by pressing the TAB-Key. But when I use the TAB-Key, the cursor jumps, out of control, from the upper left field to the middle and so on. My Question now, where can I configure, into which field the cursor juumps, after I press the TAB-Key?
greets
Marco
(3,297 Views)
You can control the order in which the control focus moves when the Tab key is pressed in the UIR editor. Select menu Edit->Tab Order and go from there.
JR
(3,297 Views)
Oh yes, thank you very much 🙂
(3,289 Views)
