LabWindows/CVI
TWAIN
Is it possible to capture images using TWAIN compatible devices?
John Cameron.
Type softly, read gently.
(3,157 Views)
Hello John,
CVI does not currently have any built in drivers for TWAIN devices. But, if you can find a C driver or an ActiveX control for TWAIN, you can use CVI 5.5 and above with the ActiveX control. CVI will generate wrapper functions (Tools >> Create ActiveX Controller) and the appropriate libraries so that you can start using the functions directly.
For more information on using ActiveX controls in CVI, take a look at the following two links:
What Are ActiveX and ActiveX Automation?
http://digital.ni.com/public.nsf/websearch/d984cf1ca889b809862565fc0078e964?OpenDocument
ActiveX
http://zone.ni.com/devzone/devzone.nsf/webcategories/A247F2BD6FD11D8D862567A90058B72D?opendocument
Let me know if you have any further questions about this issue.
Scott R
omine
Scott Romine
Course Development Engineer
(3,157 Views)
