LabWindows/CVI
TDMS Thread safe
HI!
Is it TDMS library thread safe?
Thank you in advance.
(3,776 Views)
TDMS is thread-safe, but not multi-threaded. Right now, the thread protection is pretty crude, because if you open one file in one thread and a second file in a different thread, the tdms functions in both threads will not run in parallel. All functions in both threads will execute properly (thread-safe), but you might run into timing constraints (not multi-threaded), because the functions in one thread might be waiting for the functions in the other thread to finish.
Herbert
(3,770 Views)
Hi Herbert-- we see that in 2007, TMDS is NOT multi-threaded.  Is it multi-threaded today?
Ross
(2,516 Views)
