LabWindows/CVI
System_Type
Hallo,
ich rufe ein .Net DLL  in CVI als Function Tree eingebunden. Eine Funktion benötigt einen Parameter vom Typ System_Type eines elementaren Datentyps
In VB.Net würde ich diesen Paramter mit z.B. GetType(Boolean) initialisieren.
Ich habe inzwischen die mscorlib2 Bibliothek mit eingebunden - jedoch werde ich dort nicht schlau.
Kann mir jemand sagen wie der equivalente Aufruf in CVI zu dem Beispiel von VB.Net aussehen muss. Und welche "initalisierungen" a la xxxx__Create() oder Initialize_xxx() notwendig sind.
Vielen Dank an Euch alle.
I have included a .Net DLL in CVI as a function tree. One of the functions need as paramter a type System_type, and in fact a basic data type (int, boolean...).
In VB.Net I would simply use GetType(Boolean) to get the parameter.
What to do in CVI? I have looked within the mscorlib but it is a mystery to me. Can anybody give me an example please. What type of initializations/includes are necessary like xxxx_Create() or Initilizae_xxx().
Thanks to all
(3,514 Views)
Michael69,
do you use the CVI Tool "create .NET Controller... "?
The "create .NET Controller..." actually creats a wrapper for you that provides c-function with parameters of c data types that are handle to the original .NET DLL.
What and how you are trying to include the .NET DLL, within your CVI code?
Kind regards
Tobias S.
(3,494 Views)
yes, I use(d) the Create .Net Controller for "my" .Net class and created a wrapper through the CVI system. The .Net class is a communication class labelled "ADS" for Beckhoff equipments. As for now, my tests are just a proof of concept to exchange data between the CVI-system and the Beckhoff equipment.
By now, I can successfully compile and run my code, it just doesn't provide the correct results :-((
Instead of a C# version of "GetType(boolean)",  I included the mscorlib2 (provided as instrument) and figured out and used the adequate GetType function.
Just as I said: The result of my code isn't correct and it is very likely that the reason is within this call.
I am just now switching to the C++ dll instead where it looks much more positive.
Regards
Michael
(3,490 Views)
