LabWindows/CVI
Synchronization of 2 DAQ Cards using LabWindows/CVI
I would like to use 2 E-Series DAQ-devices connected via RTSI for simultaneous data-acqusition. The sample programs I found so far do not work with my hardware. I am sure that this is merely a configuration problem but I have got no idea how to solve it. The sample program is atattched to this question.
(2,980 Views)
Hello;
You didn't mention what sort of operations need to be synchronized in between those DAQ devices, then I'm attaching a general example that shows how to sync Input operations in between the boards, using NI-DAQ funtion calls.
Hope this helps.
Filipe A.
(2,979 Views)
