LabWindows/CVI
Synchronisation with Timer
I use UDP protocole to communicate with an external machine. I have to send to this machine a bloc every 10 ms. To do this, I use a Timer with a function callback. My problem, I have now 5 panels and I find not practical to make a Timer for each Panel.
How can communicate with an external machine using a defined interval e.g. 10 ms?
Tanks for your answers!
Alex
(3,440 Views)
HI,
maybe try to use the asynchronous timer. It's a timer that is running inside a thread. Look at the sample "asyncdem.prj" : samples\toolbox\asyndem.prj.
(3,440 Views)
You do not need to add a timer to each panel. You only need to add one timer to one of the panels, and create a callback for it. Inside the callback, you can interact with any panels, even the ones that you did not place the timer on.
Mika Fukuchi
Application Engineer
(3,440 Views)
Thank you Pierre. It works...
Alex
(3,440 Views)
