LabWindows/CVI
Suggestion: View Menu Callbacks
Hello all,
here's a suggestion for the user interface editor: an option in the the
[Code][View] menu in addition to [Panel callback] and [Control callback], if
the panel has an attached menu bar, to have a [Menu callbacks] with give you
the list of callbacks and takes you wherever you want to go in the source
code.
....I'm always searching for my menu callbacks...
Guillaume Dargaud
http://www.gdargaud.net/
(5,252 Views)
Even better, right-click on a menu item and popup a menu with "View menu callback" option the same way theat we have the "View control menu" option on buttons and so on.
I seem to remember that I file such a suggestion a few years ago (or I simply discussed it with a NI technician on some NIWeek? Don't know)
(5,247 Views)
> menu
> menu" option on buttons and so on.I seem to remember that I file such
> a
> on some
> NIWeek? Don't know)
Solving problems years before I report them, how nice... C;-)
I'd never noticed this option !
Guillaume Dargaud
(5,233 Views)
It would be nice, unfortunately as of CVI8.5 it's still not present.
(I didn't have time to install release 9 till now...)
Message Edited by Roberto Bozzolo on 03-24-2009 04:03 PM
(5,230 Views)
Hi Roberto,
We did implement your suggestion, in version 8.5. If you operate a panel's menubar in the  UI Editor, in edit mode, you can right-click on any menu item and, if that menu item has a callback defined, you can either generate the callback or navigate to the callback.
(Inexplicably it says "View control callback" instead of "View menu callback", which seems bizarre to me now. I need to find out why that is. But in any case, it does the right thing).
Luis
(5,214 Views)
LuisG wrote:
Hi Roberto,
Luis
Uh oh... busted! Smiley Surprised
Seems I haven't tried it... maybe I should read more carefully the release notes Smiley Wink
Anyway, kudos to you an NI for this! Smiley Happy
(5,208 Views)
Actually... it wouldn't have been in the release notes. Sorry :-). Before 9.0 we were only including major features in the release notes. And unfortuately, the production suggestion mechanism doesn't seem to be set up to send you a notification when the status of your suggestion changes. So you really had no way of knowing unless you happened to go look for it.
Luis
(5,187 Views)
