well,
I don't think there is solution like you wish.
what I do in this case, is setting a reasonable y-scaling beforehand and then only change y-scaling when the actual data goes out of
that range.
of course, this will only fit if all data values are in a comparable range
(you won't se much on a chart with curve #1 in 5000+-10 range and curve #2 1000+-20 :).
a solution to this would be individual y-scaling for each curve - but that is not implemented
(maybe one should file this as a wish-list item ?)
Once the game is over, the king and the pawn go back into the same box.
