LabWindows/CVI
Strip Chart Autoscale
Is there really no easy way to AutoScale my Yaxis in CVI on a stripchart other than the example of keeping a history and rescaling it manually with the history...
thanks,
(4,102 Views)
Unfortunately yes. Autoscaling is only available for the graph, not for the stripchart. So you have to set the min and max value programmatically for the y-axis of a strip chart.
(4,080 Views)
Fortunately, this should not be too difficult to do. Basically I would approach it like this (as long as you want to only have the scale grow, if you want it to shrink back, that takes more logic and requires that you keep track of what is "on chart"):
Define two variables to hold the min and max scale values.
If the current value is more negative than the min, set min to that value, change the scale minimum.
Else, if the current value is more positive than the max, set max to that value, change the scale maximum.
Else do nothing.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(4,068 Views)
Here is an example of how to set this up
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E17556A4E034080020E74861&p_node=DZ52151&p_source=External
Hope this helps
Bilal Durrani
NI
(4,045 Views)
