LabWindows/CVI
Stop a while loop with array outside
I have a problem to stop running a vi which uses a while loop and outside an array with two values of intervals of time. I would like to stop the VI when the different values in the array are elapsed. I attached here the code if you like to help me please I thank you in advance.
(3,403 Views)
Hi nousome,
You better post this question to LabView forum.
This is not the best place to look for an answer since this is the LabWindows/CVI forum.
Good luck  😉
S. Eren BALCI
IMESTEK
(3,401 Views)
It seems to me that your vi can work with only a few modifications (correcting some confusion on time units -secs vs. msecs). Attached a modified version with units corrected and generalized to accept and execute on input array with variable number of elements.
*Edit*  I see you already have posted this question in LV forum.
Message Edited by Roberto Bozzolo on 11-21-2008 06:03 PM
(3,389 Views)
