LabWindows/CVI
SriptFile Logic help
im trying to get the integer this time instead of putting the integer into the ini file, its not getting the integer,im probably overwriting or someting.
can you assist me?
int main()
  int Width=0,  Height=0;
  Get_Centroid_Center ( Width,  Height)
return 0;
int Get_Centroid_Center (int frameWidth, int frameHeight)
    char dirName[500];
    IniText iniStation=0; ///< Handle for the Station INI file.
    char pathName[500];
    GetProjectDir(dirName);
    MakePathname(dirName,CONFIG_FILE3,pathName);
    if(iniStation != 0)
       Ini_Dispose(iniStation);
    Ini_ReadFromFile (iniStation,pathName);
    Ini_GetInt(iniStation, "123456789", "FRAMEWIDTH", &frameWidth);
    Ini_GetInt(iniStation, "123456789", "FRAMEHEIGHT", &frameHeight);
   // Ini_WriteToFile(iniStation, pathName);
    if(iniStation != 0)
    //system("notepad Config.ini");
    return VI_SUCCESS;
Message 21 of 33
(2,740 Views)
I suppose you want GetCentroidCenter to return the values it reads from file. For the function to do so it must receive the variables by address, otherwise it will not be able to return the values to the caller. For this to happen your code must be modified as follows:
int main()
  Get_Centroid_Center (&Width,  &Height)
  return 0;
int Get_Centroid_Center (int *frameWidth, int *frameHeight)
    char pathName[500];
    GetProjectDir(pathName);
    MakePathname(pathName, CONFIG_FILE3, pathName);
// Those lines are useless: iniStation is a local variable and here is still initialized to 0
    if(iniStation != 0)
       Ini_Dispose (iniStation);
    iniStation = Ini_New (0);   // This is absolutely needed for you to use Ini files!
    Ini_ReadFromFile (iniStation, pathName);
    Ini_GetInt (iniStation, "123456789", "FRAMEWIDTH", frameWidth);
    Ini_GetInt (iniStation, "123456789", "FRAMEHEIGHT", frameHeight);
    if(iniStation != 0)
    return VI_SUCCESS;
I have made those modifications in the code:
  1. Passed frameWidth and frameHeight by reference to Get_Centroid_Center (): this permits to get back their values (this is really a basic C mistake: you were probably thinking to something else while you were coding this, weren't you?)
  2. Deleted some lines at the beginning of Get_Centroid_Center (): in this point there is no possibility that iniStation has any value
  3. Added Ini_New at the beginning of the function: if you don't create the in-memory Ini object you won't be able to manipulate it and get / put values!
 I will say you nothing about error checking: I'm pretty sure this is only an abstract of your actual code where you have added all necessary elements to detect if an error has raised!
Message Edited by Roberto Bozzolo on 10-31-2009 07:09 PM
Message 22 of 33
(2,740 Views)
Im still not getting the values from the ini file at all, I dont know what im doing wrong.
int main()
    int width=0;
    int height=0;
    Get_Centroid_Center (&width, &height);
    return 0;
    char dirName[500];
    char pathName[500];
    iniStation=Ini_New(0);
    //Update the current file with the frame width and frame height
    //which is half of the frame. (Center)
    //This file is also associated with a serial number from the seeker
    Ini_GetInt(iniStation, "123456789", "FRAMEWIDTH", frameWidth);
    Ini_GetInt(iniStation, "123456789", "FRAMEHEIGHT", frameHeight);
    printf("%d, %d",frameWidth,frameHeight);
    GetKey();
    if(iniStation != 0)
    return VI_SUCCESS;
Message 23 of 33
(2,721 Views)
SORRY ABOUT THAT, THE PROGRAM IS WORKING. i HAD TO PUT THE PRINTF STATEMENT IN THE MAIN
INSTEAD OF THE FUNCTION CALL. THANKS ROBERTO.
Message 24 of 33
(2,669 Views)
Darnell:
Your printf() statement in Get_Centroid_Center as you posted it prints the pointers, not the values.
Your function definition for Get_Centroid_Center shows that you're using pointers:
*frameWidth and *frameHeight are int's.
frameWidth and frameHeight are pointers to int's.
printf in Get_Centroid_Center would work like this:
printf("%d, %d", *frameWidth, *frameHeight);
Message 25 of 33
(2,652 Views)
Im getting this non fatal error
NON-FATAL RUN-TIME ERROR:   "AutomationEOD_Init.c", line 397, col 7, thread id 0x000013DC:   Uninitialized string.
#define HRCHECK_FILE(sMsg)           { Write_HrChecks_To_Script_File(sMsg);}
int Write_HrChecks_To_Script_File (char stringToWrite[]);//HrCheck script file
int Write_HrChecks_To_Script_File (char stringToWrite[])//Log error script file
   FILE *textFile;
   char errorMsg[BUF_LEN];
   char textFileName[BUF_LEN];
   char statusCheckMsg[BUF_LEN];
   char newErrorMsgVariable[BUF_LEN];
   double dateTimeValue;
   size_t stringLength = 0;
   textFile = fopen ("DAS3000_SOFTWARE_ERRORS.txt", "a");
   if(textFile == NULL)
         sprintf(statusCheckMsg, "Error opening file %s", textFileName);
         MessagePopup ("File Open Error", statusCheckMsg);
      HRCHECK_FILE(statusCheckMsg);
      return FAILURE;
   else
      GetCurrentDateTime (&dateTimeValue);
      FormatDateTimeString (dateTimeValue, "%I:%M%p %A, %B %d, %Y  -----  ",
                                        errorMsg, BUF_LEN);
      strcpy(newErrorMsgVariable,errorMsg );
      sprintf (errorMsg,"%i:%s",clock(),stringToWrite); ************************** this is where i get the error, its saids uninitialized stringToWrite
      strcat(newErrorMsgVariable, errorMsg);
      stringLength = strlen(newErrorMsgVariable);
      fwrite(newErrorMsgVariable, stringLength, 1, textFile);
      fclose (textFile);
   return VI_SUCCESS;
Message 26 of 33
(2,640 Views)
Darnell:
Since you passed stringToWrite as a parameter, the routine that called Write_HrChecks_To_Script_File() would initialize it.  Take a look at the calling routine to see how the parameter you're passing to Write_HrChecks_To_Script_File() gets initialized.  Post the calling routine, if you need to, after you take a look at it.
Message Edited by Al S on 11-02-2009 12:23 PM
Message 27 of 33
(2,639 Views)
I did post the function.
unless you talking about
int hrCheck( HRESULT hresult, char function[STR_LEN])
    char *errorBuf; // Error buffer in CA_GetAutomationErrorString
    char *tempString;       // Temp string  displays error messaging
    if(FAILED( hresult ))
       errorBuf = calloc( BUF_LEN, sizeof(char) );
       tempString = calloc( BUF_LEN, sizeof(char) );
       if(!(errorBuf && tempString))
           if(errorBuf)
              free( errorBuf );
              HRCHECK_FILE(errorBuf);
           if(tempString)
              free( tempString );
              HRCHECK_FILE(tempString);
           return VI_SUCCESS;
       CA_GetAutomationErrorString( hresult, errorBuf, BUF_LEN );
       HRCHECK_FILE((char*)hresult);
       sprintf(tempString, "Error: %s\n    Function: %s\n",errorBuf,function);
       HRCHECK_FILE((char*)tempString);
       if((g_comError.wCode != 0) || (g_comError.sCode != 0))
           g_comError.sCode = 0;
           HRCHECK_FILE((char*)g_comError.sCode);
           g_comError.wCode = 0;
           HRCHECK_FILE((char*)g_comError.wCode );
       free( tempString );
       free( errorBuf );
       HRCHECK_FILE(errorBuf );
    return VI_SUCCESS;
Message 28 of 33
(2,635 Views)
Darnell:
Yes, I was talking about "the routine that called Write_HrChecks_To_Script_File()", "the calling routine".
I would suggest you put a breakpoint early in hrCheck() and step through the code so you see what call is causing your error.
There are two things I don't understand about the code you posted.
1. Why use a macro to do the following?
Why not just call Write_HrChecks_To_Script_File()?
2. (Related to your question)  I don't understand what you are doing in casting variables as pointers to char's in your calls to HRCHECK_FILE().
For example:
userint.h has the following definition:
#ifndef _HRESULT_DEFINED
#define _HRESULT_DEFINED
typedef long HRESULT;
#endif /* !_HRESULT_DEFINED */
So HRESULT is a long.  What are you trying to do by casting it as (char*)?
If you want to convert the number to a string, why not use sprintf()?
Message 29 of 33
(2,616 Views)
The function accept long, so when i want to place my function HRCHECK_FILE((char*)hresult);
i have to point it to a char. because hresult is long  if I can remember. it works either way.
so do you know why i am getting the error
Message 30 of 33
(2,607 Views)
