LabWindows/CVI
SptRealSTFTSpectrogram
Somebody could explain the use to me of the function:"SptRealSTFTSpectrogram" with an example?
I have problems with Analysis Window Information
Thank you,
(3,588 Views)
Hello smd,
could you be more precise on what problems you are getting? Also, is this function correctly spelled? Where does it come from? Is it the Spectral Measurements Toolset from NI?
About the windowing, what it will do is to apply a window to the data points (block) on which the algorithm will calculate the FFT or STFT, reducing the effect of mathematically considering the signal to be analyzed as an infinite repetition of the block. This is a rather short explanation, you should check out for more info if what you really want is to understand the benefits and methods used. Here's some (although not specific to STFT or spectrograms):
http://zone.ni.com/devzone/conceptd.nsf/webmain/E0F0B1FFE86A14A986256F2E0005AF4D
http://zone.ni.com/devzone/conceptd.nsf/webmain/d493a06a5a5b0ae1862568c100695ce2?OpenDocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/81E934672ABEB3D4862568C1006528F4?opendocument
Jorge M.
(3,549 Views)
Thank you for the answer, Jorge, but I have already solved the problem.
I found an example of the utility of the function in the Signal Processing Toolselt 6.0
Thank you again
(3,525 Views)
