LabWindows/CVI
'Speed' errors while accessing mouse click events?
   I have built a software where the the panel has a CVI callback function registered. The function tests whether for two cases, first EVENT_LEFT_CLICK, and then EVENT_LEFT_CLICK_UP. The user is supposed to maintain the click pressed for a while (~1 second), and there is no problem there. However, I have found that if by error (that users often commit) several quick clicks are made, sometimes the click down event (EVENT_LEFT_CLICK) piece of code is not read. I have reduced the probability of that problem by setting the speed of double click (on Windows) at the maximum.
I suspect that if I could eliminate the double click event, this problem would be almost completely solved, and only limited by the speed at which the processor can update the mouse events.
Hope you understand my problem.
Thanks!!
(4,123 Views)
Accepted by topic author Sincrono
AUTOSOLVED.
Thanks to some guy who posted his own solution on a Windows forum, to 'disable' the double-click. Just have to change registry value of HKEY_CURRENT  >  ControlPanel  >  Mouse  >  DoubleClickSpeed      to 1. Actually, this makes the double click speed so fast that you can access virtually all user-made single clicks.
After doing this, in order to apply the registry edition, I terminated the execution of explorer.exe, and relaunched it through the task monitor of windows. However, the change this not apply until I opened the mouse control panel (without changing or applying anything from there).
(4,075 Views)
