LabWindows/CVI
Sort table rows by date
I've got a date field in my table which isn't in standard format (it's a string). Is it possible to adjust the function SortTableCells to make my own sort rules?
Image Hosted by ImageShack.us
(3,479 Views)
SortTableCells relies on other functions to do the comparison. The second to last parameter you pass to SortTableCells is a pointer to the function.
From userint.h:
int CVIFUNC SortTableCells (int panel, int control, Rect cellRange, int direction, int keyIndex,
int descending, CellCompareCallbackPtr comparisonFunction,
void *callbackData);
Look at the colview.prj sample project that ships with CVI. It defines a function SortByDate and then tells SortTableCells to call that function. You can create your own comparison function that reads and compares your date format.
(3,479 Views)
Thanks!
(3,479 Views)
