LabWindows/CVI
Slow program when started with desktop shortcut
My program is running without problems if it's started from the Windows Explorer, but if it's started with a desktop shortcut it runs (somtimes!) VERY slow. I've tried to create the shortcut in different ways, but nothing seems to help. It runs on Windows XP and is once installed on the computer, but the executable is run over network. Does anyone have any ideas?
(4,233 Views)
I am having the same issue with 2 pcs at a remote site. I would be interested to hear if you were able to resolve it.
(4,181 Views)
Haven't solved it, but worked around it... I created a batch file that starts the program. It's no problem to have a shortcut for the batch file on the desktop. Still interessted in why it doesn't work with a normal shortcut.
(4,172 Views)
Hi, got the same problem with 6 pc on winxp and a win2000 server. Any solution yet?
(4,137 Views)
The problem is probably the start path right click on your shortcut and go to properties and set the start in directory to the correct directy for your app OR the programtic solution is to do the following (note include windows.h)
char path[MAC_PATH];
GetModuleFileName(0, path, MAX_PATH) ;
SetDir(path) ;
and that will fix it also
(4,134 Views)
oooops check that the code should be
char path[MAX_PATH] ;
*(strrchr(path, '\\') + 1) = '\0';
SetDir(MotanaExecDir) ;
(4,133 Views)
Hey!!!
I found the asnwer to my problem
Windows Update KB887742
itresolve a problem with the windows firewall and some antivirus conflict.
(4,125 Views)
