LabWindows/CVI
Sherborne WTS Inclinometers
Has anyone tried to interface to the Sherborne WTS inclinometers using their USB base station and the DLL they provided?  There doesn't seem to be an overabundance of information in their documentation.  I can't find a static library or header file included with it so it appears it'll have to be a run-time link to the DLL.  What documentation they do include in their manual is focused on VB.
(2,575 Views)
Hey mklusman,
I believe you should need the header file with the DLL in order to create a static library if a .lib isn't already included. You may have better luck reaching out to Sherborne directly to see if they could provide those source files. I went ahead and looked up their contact info so hopefully they'll be able to provide you with the information you need.
Phone: (201) -258-4647
Email: applications@sherbornesensors.com
Applications Engineering
(2,537 Views)
Finally, did you have a return from sherborne on this
(2,505 Views)
I had reached out to them prior to this regarding a static .lib but have yet to get a response.  Unfortunately I've not had a chance to follow-up with them on it since then.
(2,502 Views)
