LabWindows/CVI
SetupDiGetClassDevs
I
Which include must i use in Labwindows/CVI to compil "SetupDiGetClassDevs"
I try to compil it with VS2008 and i succed . But i must do my Dll under CVI.
WinDDK is installed on my computer.
(5,447 Views)
hi Jerome,
What this function is referenced to?
What is the aim of this function?
If you succeeded to compil it with VS2008, which header file did you include?
Olivier L. | Certified LabVIEW Developer
(5,413 Views)
maybe this link will help : here
It's a C source file which uses SetupDiGetClassDevs
So, I suppose you've used the Setupapi.h include file to compile under VS2008
Maybe you've got to specify the library path for the CVI project? Or add it to your project?
Message Edité par NI_Device_user_sb le 06-04-2008 06:29 AM
(5,406 Views)
Ok, thanks, in fact CVI sdk wasn't installed ...
My work was to comunicate with a PCI driver registered with a class interface.
Now it is ok.
(5,379 Views)
