LabWindows/CVI
SetUpDDEHotLink()
I am using LabWindows/CVI as a DDE client and I have other DDE server. I want to read the data from the server and show the data in the user interface.
Basic flow I did is like the following:
SetUpDDEHotLink()
ClientDDERead()
SetCtrlValue()
But the problem is that it shows the current value in the user interface and it won't update when the data changes. How can I make the data updated dynamically according to the data in the server?
Joyce
(2,912 Views)
Hi Joyce,
Hope you had a good weekend!  Typically when you are want to refresh your user interface, you would use GetUserEvents or RunUserInterace.  If you are using a processor intensive application, you could look into using ProcessDrawEvents.  I hope this helps!
Matt S
(2,895 Views)
