LabWindows/CVI
Set server port for InetSendMail
My smtp mail server is not on port 25.  How do I configure the InetSendMail function to use a different port?
(4,712 Views)
Hi TucsonJB,
In the following link you can find the information related to the parameters that you can set to the InetSendMail function from LabWindows/CVI
Hope you can find it helpful!
Sil.VI
(4,692 Views)
No, that doesn't help.  The only parameter that has anything to do with the mail server is the SERVER parameter.
No parameter contains port information.
Is there a way to include the port number along with the server name?
Does anyone use a server that uses the default port?
(4,672 Views)
