LabWindows/CVI
Serial connection
Currently I am using CVI but I am facing some issue. I want to connect a wifi dongle with serial connection and control that with cvi. But I don't know if it exist a function in cvi which could do that? Could you help me if that exist
(2,420 Views)
You mean a serial over wifi USB adapter ? When you connect it, you should see a new serial device appear in the Windows System Hardware manager. Use that name (COM something) in the SerialOpen() call, it should work as a normal serial port as seen from CVI.
Caveat: I've hard reliability issues with this kind of equipment.
(2,343 Views)
