LabWindows/CVI
Second derivative
Hello all,
this is rather elementary numberical question, but I haven't done this in a while... Say I have 2 arrays: V[] and I[]. The 1st order derivative dI/dV can be computed for each point with:
Der1[i]=(I[i+1]-I[i])/(V[i+1]-V[i])
But what's the formula for second order derivatives ? i.e.: d2I/dV2 ?
I see the advanced library function difference(), but it only deals with dt. Is there a function that I can use ?
Message 1 of 8
(4,967 Views)
Accepted by topic author gdargaud
Maybe too simplistic, but why not calulating the derivative of the derivative?
Der2[i]=(Der1[i+1]-Der1[i])/(V[i+1]-V[i])
Message 2 of 8
(4,963 Views)
I am not using the simple form... but instead I adapted the function from the GNU scientific library
Message 3 of 8
(4,957 Views)
I should have added that it was my 1st idea, but I wasn't sure the divisor was correct. Also, shouldn't there be a /2 for each computation ?
Message 4 of 8
(4,956 Views)
Generally speaking, how would you want to filter the data before derivation ? There's little noise in it, but what little there is makes it hard on the 2nd derivative...So I was thinking of a lowpass filter.
And worse, since I derivate according to V, if V is not strictly growing (or decreasing), I get divide by zero. So maybe I also need a highpass filter!
Is there some generic data massaging protocol better than a large bandpass filter before doing a derivative ?
Message 5 of 8
(4,926 Views)
Ha, I'd missed the part about the 5-point vs 3-point and error estimate. But still, I don't see how to use gsl_deriv_central in the case of dI/dV where I and V are 2 arrays of values. Sorry, my signal processing skill have gone rusty in recent decades.
Message 6 of 8
(4,918 Views)
well - I have slightly rewritten the routine because of some constraints; one is that I am also dealing with arrays - but the main idea remains the same, i.e., calculate more data points to allow for some error estimate which then in turn is used to find the optimum step size.
Message 7 of 8
(4,914 Views)
/// HIFN	Compute dI/dV by finite difference method
/// HIFN	See https://en.wikipedia.org/wiki/Finite_difference_coefficient
/// HIPAR	I / Dividand input arrays
/// HIPAR	V / Divisor input array
/// HIPAR	n / Size of I and V
/// HIPAR	D / Output array, of size n-1
/// HIPAR	Method / 2 (forward)  or 3,5,7,9 (central)
/// OUT		D
void Derivate(double I[], double V[], int n, double D[], int Points) {
// Accuracy 1 - Forward
	#define D2(A) (A[j]-A[j-1])
// Accuracy 2 - Central
	#define D3(A) (-A[j+1]+A[j-1])
// Accuracy 4 - Forward
//	#define EVAL5 (-25*I[j]+48*I[j-1]-36*I[j-2]+16*I[j-3]-3*I[j-4])/(-12*(V[j]-V[j-1] ??? ))
// Accuracy 4 - Central
	#define D5(A) (A[j+2]-8*A[j+1]+8*A[j-1]-A[j-2])
// Accuracy 6 - Central
	#define D7(A) (-A[j+3]+9*A[j+2]-45*A[j+1]+45*A[j-1]-9*A[j-2]+A[j-3])
// Accuracy 8 - Central
	#define D9(A) (3*A[j+4]-32*A[j+3]+168*A[j+2]-672*A[j+1]+672*A[j-1]-168*A[j-2]+32*A[j-3]-3*A[j-4])
	switch (Points) {
		case 2: for (int j=1; j<n  ; j++) D[j-1]=D2(I)/D2(V);                                          D[n-1]=0; break;
		case 3: for (int j=1; j<n-1; j++) D[j]  =D3(I)/D3(V); D[0]=                                    D[n-1]=0; break;
		case 5: for (int j=2; j<n-2; j++) D[j]  =D5(I)/D5(V); D[0]=D[1]=                        D[n-2]=D[n-1]=0; break;
		case 7: for (int j=3; j<n-3; j++) D[j]  =D7(I)/D7(V); D[0]=D[1]=D[2]=            D[n-3]=D[n-2]=D[n-1]=0; break;
		case 9: for (int j=4; j<n-4; j++) D[j]  =D9(I)/D9(V); D[0]=D[1]=D[2]=D[3]=D[n-4]=D[n-3]=D[n-2]=D[n-1]=0; break;
		default: break;
/// HIFN	Compute d2I/dV2 by finite difference method
/// HIPAR	Points / 3,5,7,9 (central), -2,-3,-5,-7,-9, iterate Derivate twice with |Points|
void Derivate2(double I[], double V[], int n, double D[], int Points) {
	#define DD3(A) (A[j+1]-2*A[j]+A[j-1])
	#define DD5(A) (-A[j+2]+16*A[j+1]-30*A[j]+16*A[j-1]-A[j-2])
	#define DD7(A) (2*A[j+3]-27*A[j+2]+270*A[j+1]-490*A[j]+270*A[j-1]-27*A[j-2]+2*A[j-3])
	#define DD9(A) (-9*A[j+4]+128*A[j+3]-1008*A[j+2]+8064*A[j+1]-14350*A[j]+8064*A[j-1]-1008*A[j-2]+128*A[j-3]-9*A[j-4])
	switch (Points) {
		case -2:
		case -3:
		case -5:
		case -7:
		case -9: { double d[n]; Derivate(I, V, n, d, -Points); Derivate(d, V, n, D, -Points); } break;
//		Those are wrong
//		case 3: for (int j=1; j<n-1; j++) D[j]=DD3(I)/DD3(V); D[0]=D[n-1]=0; break;
//		case 5: for (int j=2; j<n-2; j++) D[j]=DD5(I)/DD5(V); D[0]=D[1]=D[n-2]=D[n-1]=0; break;
//		case 7: for (int j=3; j<n-3; j++) D[j]=DD7(I)/DD7(V); D[0]=D[1]=D[2]=D[n-3]=D[n-2]=D[n-1]=0; break;
//		case 9: for (int j=4; j<n-4; j++) D[j]=DD9(I)/DD9(V); D[0]=D[1]=D[2]=D[3]=D[n-4]=D[n-3]=D[n-2]=D[n-1]=0; break;
		case 3: for (int j=1; j<n-1; j++) D[j]=4*DD3(I)/(     D3(V)*D3(V)); D[0]=                                    D[n-1]=0; break;
		case 5: for (int j=2; j<n-2; j++) D[j]=4*DD5(I)/(12*  D3(V)*D3(V)); D[0]=D[1]=                        D[n-2]=D[n-1]=0; break;
		case 7: for (int j=3; j<n-3; j++) D[j]=4*DD7(I)/(180* D3(V)*D3(V)); D[0]=D[1]=D[2]=            D[n-3]=D[n-2]=D[n-1]=0; break;
		case 9: for (int j=4; j<n-4; j++) D[j]=4*DD9(I)/(5040*D3(V)*D3(V)); D[0]=D[1]=D[2]=D[3]=D[n-4]=D[n-3]=D[n-2]=D[n-1]=0; break;
		default: break;
#if 0
#include <stdio.h>
#define N 20
double f(double x) {
//	return 10;	// 0 everywhere
//	return x; 	// 1 for D, 0 for DD
//	return x*x; // 2x+1 for D2, 2x for Dn, 2 for DD
//	return x*x*x;
	return exp(x);
int main (int argc, char *argv[]) {
	double I[N], V[N], D2[N], D3[N], D5[N], D7[N], D9[N], DD2[N], DD3[N], DD5[N], DD7[N], DD9[N];
	for (int i=0; i<N; i++) I[i]=f(V[i]=i);
	Derivate (I, V, N, D2, 2);
	Derivate (I, V, N, D3, 3);
	Derivate (I, V, N, D5, 5);
	Derivate (I, V, N, D7, 7);
	Derivate (I, V, N, D9, 9);
	Derivate2(I, V, N, DD2, 2);
	Derivate2(I, V, N, DD3, 3);
	Derivate2(I, V, N, DD5, 5);
	Derivate2(I, V, N, DD7, 7);
	Derivate2(I, V, N, DD9, 9);
		printf("I\tV=x\tForw 3 5 7 9\tForw 3 5 7 9\n");
		printf("%.4g %g\t%.4g %.4g %.4g %.4g %.4g\t%.4g %.4g %.4g %.4g %.4g\n",
			   I[i], V[i], D2[i], D3[i], D5[i], D7[i], D9[i], DD2[i], DD3[i], DD5[i], DD7[i], DD9[i]);
	return 0;
#endif
I've written the above based on the finite difference method. I'm pretty sure it's correct for the 1st derivative.
But for the 2nd derivative, what do I divide with ? The various formulas I see are always for dI/dt where dt is constant (actually 1), and in that case they divide by dt^2. But here since my dV is (slightly) variable, I don't know what to use.
For a 3-point central double derivative, it seems straightforward to use a 3-point central difference squared, but I'm not too sure about it or about the higher orders.
Message 8 of 8
(4,870 Views)
